How do I get my film to fit this size/format in Final Cut Pro 7?
Melissa Cordova
on Aug 28, 2014 at 10:52:18 am
1. Quicktime format at 1920x1080 resolution with audio.
2. Videos must be no more then 720px wide, under 200MB, and in .mov format
Thank you!
Shane Ross
Re: How do I get my film to fit this size/format in Final Cut Pro 7?
on Aug 28, 2014 at 3:38:23 pm
Those are not only contradictory, but lacking information. 1920x1080...AND 720? Makes no sense. The video needs to be either 1920x1080, or 1280x720. Can't have 1920x1080 that's 720p.
Quicktime, by nature, is MOV format. But what codec do they want? I'm assuming H.264. So, you can compress to 1280x720 H.264 as a QT MOV. But how LONG is the piece? Because the quality of the export...the data rate...to get it to 200MB..depends on the duration of your video.
Shane
Little Frog Post
