Diagonal Split In FCP 7
Shitij Kohli
on Aug 28, 2014 at 4:41:26 am
Hello,
I wanted diagonal split in FCP7, for that i did a 8 point Garbage Matte & split the two clips diagonally....but my client wants a black line separating the two diagonal clips.
As u might be aware that there would not be a separating line between the two clips in 8 point garbage matte (at most a feather)....so then i did some research & i saw this video:
Final Cut Pro Tutorial #1:Diagonal Split Screen Effect
Basically this is a tutorial about 3 way split & there was a psd file attached to achieve this look...i took the file to photoshop to create my own diagonal split...& here i am struck as my photoshop skills are not that great, i am unable to make two diagonal shape layers (actually i do make, but when i take the psd file to fcp it doesn't open up in layers, as shown in the video).
Could someone kindly help me in making a diagonal split in photoshop & attach the file....would be highly obliged.
I have attached the psd file from the Diagonal Split Screen Effect tutorial from youtube.
Thanks!!!
Dave LaRonde
Re: Diagonal Split In FCP 7
on Aug 28, 2014 at 6:55:46 pm
Doesn't FCP have a bordered diagonal wipe that you can keyframe... as in, "don't wipe past this point"?
Dave LaRonde
Promotion Producer
Nick Meyers
on Aug 29, 2014 at 6:38:48 pm
Or copy the garbage mate to the other clip,
Invert it and tweak
Nick
Mark Suszko
on Aug 30, 2014 at 5:09:11 am
Or make each clip its own layer, over a black first layer, and use the mask tool, your black line comes from the offset of each clip relative to the next.
