Set in-point for multiple clips at once
Ella Currer
on Aug 22, 2014 at 4:04:47 pm
I'd like to set my many clips' in-points to one frame in rather than zero. I am trying to find a way to do that by selecting all clips and right clicking in the Browser's "In" column but not finding a way. I know I can utilize that function to CLEAR the ins across multiple clips but is there a way to set a uniform IN?
Thanks for any thoughts.
E
Nick Meyers
Re: Set in-point for multiple clips at once
on Aug 23, 2014 at 8:31:22 am
not really.
manual is probably the quickest way.
why do you want to do it anyway?
could be a better way to achieve what you want.
nick
John Pale
on Aug 25, 2014 at 8:03:48 pm
Export the bin as a batch list.
Open in Excel and make your adjustments. Not an Excel whiz, but I am guessing there is a way to copy the data from the Media Start column to the In column, then increment all of it by 1 frame.
Then import your adjusted Batch List back into FCP and relink.
Ella Currer
on Aug 25, 2014 at 8:39:44 pm
Thanks for the idea. I adjust the Batch list In in Excel but the modified In resets back to zero upon import. Doesn't seem to work. Would love if this were a feature same as the right+click "Clear In"!
The reason I need to adjust many clips one frame is they were delivered with a one frame title card at the head so need to adjust to get that out.
Nick Meyers
on Aug 25, 2014 at 10:53:05 pm
adjust a batch list? surely that would have taken LONGER than just doing it manually?
ok, here's a way that's pretty quick IMO:
drag all clips to a new timeline
select 1st edit, toggle selection (with U key) so you are set up for a ripple action
(or just use the ripple tool for that matter)
now use > key to ripple 1 frame,
then left arrow to jump to next edit
then >, Left arrow away till all clips are trimmed.
you could probably do a hundred in less than a minute
now you can copy / paste back to a new bin.
nick
Ella Currer
on Aug 25, 2014 at 11:07:50 pm
Changing the In in Excel with Batch List is actually easy with a one-time copy/paste of the 00:00:00:01 timecode in the In column, but as I said, it doesn't hold upon import of the list so does indeed wind up being a waste of time.
Your solution would be great if laying all clips into a timeline didn't lay them in as their full duration so therefore no handles to ripple edit.
Easiest/fastest way I've found is to click each clip's In timecode in the Browser and type "1" to set the in to 1 frame in.
FCP feature request!
Nick Meyers
on Aug 26, 2014 at 12:58:06 am
you don't need a handle as you are TRIMMING the shot.
nick
Ella Currer
on Aug 26, 2014 at 8:38:16 pm
You're right, Nick. Thanks.
