Final Cut Pro 7 Transitions Not Working On A Reversed Clip
Matthew Green
on Aug 20, 2014 at 1:25:06 pm
I have noticed that everytime I try and add a transition to a clip I have sped up, slowed down or reversed. Final Cut Pro doesnt let me add it in, is there a reason for this? and how can I change it?
Shane Ross
Re: Final Cut Pro 7 Transitions Not Working On A Reversed Clip
on Aug 20, 2014 at 11:30:49 pm
Have enough handles to allow for this?
Shane
Little Frog Post
Matthew Green
on Aug 20, 2014 at 11:36:19 pm
I am quite new to using final cut pro 7, so what do you mean by the term 'handles'
thanks
matthew
Mark Suszko
on Aug 21, 2014 at 1:37:24 pm
Handles refers to a margin of a few extra seconds of footage on the ends a clip, enough to cover a transition. If the handles are not long enough, you can't make the transition work because you run out of frames before the transition is completed.
