Matrox MXO2 Causes Timeline Scrub to Lag and Stutter
W. Lawrence Stevens
on Aug 15, 2014 at 5:44:59 pm
In our ever continuing endeavor to save expenses and accomplish some remaining SD delivery obligations in-house, we acquired a DVWM-2000 Digibeta deck to work with our FCP7 system which is normally used to output HD. To interface the deck with FCP for machine control, we were told to go with the Matrox MX02. Once everything was installed, scrubbing the timeline became tortured. It lags and stutters as if there is buffering problem somewhere.
The problem only occurs when View --> External Video is on (all frames or single) We have disconnected the deck and monitor and tried all of the applicable Matrox options under View --> Video Playback. The setting we want to use is MXO2-1080i YUV 8 bit 1920x1080. The Blackmagic Intensity Pro setting we were using prior to the Matrox installation to interface with the external monitor works just fine.
Here's our setup:
MacPro 2,1, OS 10.7.5 (Lion) 2 x 3 Ghz Quad-Core Intel X5365 Xeon (8 core), 18 GB DDR2 FB-DIMM
Graphics: ATI Radeon HD 5870 1024 MB w/ Cinema HD 30"
FCP 7.03
Matrox MXO2 running 2.6.1.0001
Firmware: 36.10
External Monitor: SONY PVM-20L5 MULTIFORMAT MONITOR 20" W/BKM-142HD/SDI
We have tried adjusting just about all of the system preferences both in FCP and on the Matrox control panel. Any help in sorting this out is appreciated!
PMW-350
EX1-R
Nikon D4
(wlstevens.com)
David Roth Weiss
Re: Matrox MXO2 Causes Timeline Scrub to Lag and Stutter
on Aug 15, 2014 at 6:23:51 pm
I've never encountered an issue like that on my MXO2. Are you 100% certain you have the correct drivers installed for Lion? That's essential, as you stated you are running on Lion.
David Roth Weiss
ProMax Systems
Burbank
DRW@ProMax.com
Sales | Integration | Support
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
W. Lawrence Stevens
on Aug 15, 2014 at 6:40:02 pm
David: Yes, absolutely. This is Matrox' online description of their Driver Version 2.6.10001:
"Installs the Matrox MXO2 v2.6.1 (build 1) software for Mac OS X Mountain Lion (10.8.2) and Lion (10.7.5). This software supports Apple Final Cut Pro 7.0.3, and Adobe Premiere Pro 5.5.2."
PMW-350
EX1-R
Nikon D4
(wlstevens.com)
