FCP7 Sudden Stutter playback after rendering
michael saul
on Aug 10, 2014 at 6:20:35 pm
I'm editing a feature film 1920x1080 23.98 on Final cut Pro 7 (See hardware below). I've been editing the same file, same machine, same external drives, media and configuration for over 6 months. Suddenly I get a picture stutter which seems degenerative (gets worse with time) after rendering picture or audio (the problem is global. Other projects on other drives do exactly the same thing) I"ve re-installed FCP, tried a new user profile, repaired permissions, verified all disks, taken lots of suggestions from others and nothing seems to work. Anyone have any suggestions? I'm desperate.
Thanks for any ideas.
Mac Pro Early 2009
2.66 GHz Quad Core Intel Xeon
26mg RAM
NIVIDIA Gforce GT 120 512 mg
OSX 10.9.4
Shane Ross
Re: FCP7 Sudden Stutter playback after rendering
on Aug 11, 2014 at 3:59:11 am
Codec of the footage? Sequence settings? What external drives? Connected how?
Shane
Little Frog Post
michael saul
on Aug 11, 2014 at 4:14:20 am
ProRes 422 codec
Sequence:
1920 x 1080 aspect HDTV 1080i
Square aspect ratio
Compressor Apple ProRes 422
4 External Drives via firewire 800
Shane Ross
on Aug 11, 2014 at 7:01:46 am
How full are those drives? For maximum speed, you need to make sure that the drives have 20% space empty. Meaning only 80% full. For a 1TB drive, that means 800GB of material on it only. Any more than that and the drives slow down.
Shane
Little Frog Post
michael saul
on Aug 11, 2014 at 3:11:51 pm
Each of the drives has plenty of space. Once again though, it doesn't matter what project I open on what drive, I get the same result.
Shane Ross
on Aug 11, 2014 at 4:39:14 pm
Did you trash preferences?
Shane
Little Frog Post
michael saul
on Aug 11, 2014 at 4:51:42 pm
Yes, that was the first thing I did.
