FCP and After Effects Windows: best codec?
Zopiro da Tracia
on Jul 30, 2014 at 8:00:41 am
I still do a lot of FCP7 editing using Apple ProRes codec on my Mac. Since I recently acquired a very fast PC, I plan on using it for work on After Effects CS6 (soon CC).
I'll be moving rendered files from FCP7 to AE and vice-versa. I noticed AE on Windows lacks the ProRes codec. I've tried rendering in AE using Lossless in both QT and AVI but when importing to FCP there's a very noticeable color difference...
What's my best course of action here?
Walter Soyka
Re: FCP and After Effects Windows: best codec?
on Jul 30, 2014 at 5:29:25 pm
Final Cut Pro misinterprets the gamma on RGB formats.
Import the clip into FCP. Select the clip, then hit Cmd-9 to open Item Properties. Right-click the gamma value (normally set to Source) and set it to 2.2.
Other options:
Miraizon has a ProRes-compatible codec for Windows. You could try encoding with that.
You could also consider running Premiere Pro on your PC alongside Ae.
Walter Soyka
