Frustrating problem about subtitle
George Roberson
on Jul 27, 2014 at 6:39:20 am
I imported XML file into FCP, but I need change all the fonts from white to yellow. How to do it? I can change one by one, but there is like 1000 works to change one by one. Is there any way to change it as a group?
I went back to subtitle edit, couldn't change it there.
please help!
george
George Roberson
Re: Frustrating problem about subtitle
on Jul 27, 2014 at 7:17:45 am
this is killing me. I have 800 subtitles, do i need to change it one by one to a differnt font size and color?
Nick Meyers
on Jul 27, 2014 at 8:25:33 am
you cant batch modify text generators in FCP
there is an app you can use: Title Exchange Pro
or you can do a find & replace in the XML file for the attributes for colour & size.
create one subtitle the way you like it, place it in a new timeline and export an XML.
open that XML in text edit, or similar and find the appropriate attributes. (size = xx for instance)
then open the original XML in text edit, and do a find / replace. (size = xx to size = yy)
should work!
nick
George Roberson
on Jul 28, 2014 at 4:39:22 am
Thanks! I think I am just gonna keep the default color (white).
Nick Meyers
on Jul 28, 2014 at 7:02:29 am
you can cheat the colour in.
make sure you have all your subtitles text generators on one track
on a track above that lay some colour.
right click on the colour, and change it;s composite mode to Travel Matte - Luma.
if you need drop shadow, then you need to create a duplicate layer of the text generator.
so in the basic form you'd have:
V1= image
V2 = text (will keep hte drop shadow)
V3 = text (will lose drop shadow, but adopt colour from V4)
V4 = colour
of course you can use the wireframe to alter the size of the subs, but if you make them too large they'll go a bit soft.
nick
George Roberson
on Jul 28, 2014 at 7:40:21 pm
Thanks man. Too much for me to handle. Appreciate your input...
