FCP 7 won't recognize Canon XHA1
Maxi Cohen
on Jul 17, 2014 at 4:58:53 pm
I'm trying to capture footage in FCP 7 from a Canon XH A1, but it's not being recognized.
I've tried using both a 4 pin to 9 pin firewire, and 4 pin to 6 pin firewire, but neither works.
Computer:
Mac Pro
MacPro1, 1
Dual-Core Intel Xeon
2.66 GHz
Any suggestions would be greatly appreciated!
Model Name: Mac Pro
Final Cut Pro 7, Mac OS X (10.7.5)
Shane Ross
Re: FCP 7 won't recognize Canon XHA1
on Jul 17, 2014 at 5:50:26 pm
Did you choose an HDV Easy Setup?
Shane
Little Frog Post
Christopher McDonell
Re: FCP 7 won\'t recognize Canon XHA1
on Aug 4, 2014 at 7:00:13 am
Hey did you get it working? I have the same camera but use Fcp 6. I've found that I have to turn the camera on first, and with the heads still engaged, then start FCP. If I turn the camera on after fcp has loaded, it won't recognize the camera. If the heads disengage before I load fcp, it also won't recognize. Just one of those things...
