from 29.96 to 24fps
David Carey
from 29.96 to 24fps
on Jul 16, 2014 at 4:11:16 pm
Hello
I need to export a 24fps video file from a sequence that is 29.96. I've tried it and have problems with audio sync. Can anyone help me with this concern? I would truly appreciate and help.
thank you
David
Shane Ross
Re: from 29.96 to 24fps
on Jul 16, 2014 at 4:45:30 pm
24fps STRAIGHT UP? Not 23.976? What's this for?
The best thing to do is export a full res, self contained QT file at 29.97...and then use Compressor to convert to 24 (23.98). Set the Frame Controls in the Inspector all the BEST. And this will take a while.
Shane
Little Frog Post
