DVDs burned in DVD Studio Pro won't play anywhere
John Weber
on Jul 2, 2014 at 2:17:44 am
So I have a 1280x720 60p project that I run through Compressor using the standard "DVD: Best Quality 120 Minutes" presets in Compressor. Then I take the video into DVD SP and burn it, and the video won't play in any DVD player. Help, please and thank you?
Shane Ross
Re: DVDs burned in DVD Studio Pro won't play anywhere
on Jul 2, 2014 at 2:22:57 am
Are you sure you didn't accidentally use an HD DVD preset?
Shane
Little Frog Post
John Weber
on Jul 2, 2014 at 2:37:59 am
Don't believe so. These are the Compressor settings. Don't know how to alter DVD SP's settings, so I'm using the defaults.
http://images.creativecow.net/229818/screenshot2014-07-01at10.33.40pm.png
David Roth Weiss
on Jul 2, 2014 at 3:05:46 am
So, now what did you do for the audio? Did you use the AC3 preset for that?
David Roth Weiss
ProMax Systems
Burbank
DRW@ProMax.com
Sales | Integration | Support
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
John Weber
on Jul 2, 2014 at 3:10:55 am
I did, yes. My settings were shown in the attache picture from my last post on this thread.
David Roth Weiss
on Jul 2, 2014 at 3:17:48 am
Just wanted to make certain you used the AC3 audio preset too, as many think that's optional, when in fact not using it can make DVDs either unplayable, or virtually so.
So, what type of DVD media did you use? The good stuff, or blank media you bought at Office Depot?
David Roth Weiss
ProMax Systems
Burbank
DRW@ProMax.com
John Weber
on Jul 2, 2014 at 3:26:02 am
Blank stuff from Wal-mart. Memorex DVD-Rs. "16x, 4.7GB, 120 min"
I'd rather not wait till mornign if I have to, and would rather not spend more than I have to. And this method has worked before, so I don't know why it isn't now.
I tried buring the files straight to DVD through Compressor, which DID work. So i'm led to believe that the issue lies in DVD SP and not Compressor. But I don't believe I've changed anything in DVD SP from what I've done in the past, so I'm left confused as to what to do.
Dave LaRonde
on Jul 2, 2014 at 5:00:25 pm
Wait a minute...
You burned Mpeg2/ac3 files to a DVD -- which worked -- but DVDSP didn't? What are you making, a data DVD that's just a piece of storage media containing files, or an AUTHORED DVD suitable for playing in a DVD player?
Dave LaRonde
Promotion Producer
John Pale
on Jul 2, 2014 at 5:47:51 pm
Be certain your DVD Project in DVD SP is not set to HD DVD. If it is, your disc won't play anywhere.
Even if your assets are SD, its still possible your project in DVDSP is set for HD DVD.
