Syncing 25 frames to 60 frames
John Weber
on Jun 26, 2014 at 7:46:45 pm
I'm trying to sync up footage of the same action from two different sources. One is a skype interview recorded at 25 FPS, the other is a Canon vixia at 60 FPS. I've tried transcoding the footage to match each other, and it starts off fine but is always out of sync by the end. Need advice to fix this please, and reshooting is not an option at this point.
Thank you.
