FCP not supported on architecture
Kathryn Barnier
on Jun 19, 2014 at 7:15:07 pm
I cannot open my FCP application (7.0.3) although I've been editing on it for years. The prompt says, "You can't open the application "Final Cut Pro" because it is not supported on this architecture." First I trashed the preferences - no luck. I then re-installed FCP with the install disk. No luck. I had recently installed Black Magic, so I un-installed that. I was working with a project that came to me from a FCP 6 system, and was in the process of copying some media files from that project when the system stopped working.
Do you have any suggestions to get me back on track? I've spoken to several tech people at post houses who don't know what could be causing this. Will I have to buy another copy of FCP 7 on the off chance that my install disk is corrupt?
Shane Ross
Re: FCP not supported on architecture
on Jun 19, 2014 at 7:37:19 pm
Try the solution found here:
https://discussions.apple.com/message/9338054
To get inside the FCP app, right-click on it and choose SHOW PACKAGE CONTENTS.
Shane
Little Frog Post
