How do I highlight a moving object?
James Thomas
on Jun 18, 2014 at 5:29:04 pm
I am putting together surveillence videos and I need to place an oval or highlighted shape over the object being viewed. I see this in many videos, but cannot figure out how to do it in FCP 7.
The circle under shapes is solid color only. I can lower the opacity, but when I put motion to it the black shaded area around the shape moves with it.
I have tried creating a circle in photoshop and putting it on my clip, but had no luck.
Mark Suszko
Re: How do I highlight a moving object?
on Jun 18, 2014 at 6:21:01 pm
Change the blending mode of the shape, MODIFY>COMPOSITE MODE, then adjust opacity.
James Thomas
on Jun 18, 2014 at 7:41:40 pm
Thank you. That will work. I also found out I can use slug with a mask shape filter.
