Keyframing problem...
Oscar Gotti
on Jun 17, 2014 at 11:35:33 pm
Hello,
I am on a 1080i project on FCP 7 and I am trying to do a creeping effect on text much like you see in Movie Trailers. However, every time I do this I see a slight weird wobbling effect on the text as it moves closer and closer to the screen... Is there any way to get rid of this?
M
Andrew Rendell
Re: Keyframing problem...
on Jun 18, 2014 at 11:29:04 am
I guess you're looking at it as a real time effect, usually rendering it fixes the problem.
Mark Suszko
on Jun 18, 2014 at 2:08:36 pm
Might be an aliasing problem as well, depends on the size and type of fonts used. If you have FCP7 you must have Motion as well: have you tried doing the effect in Apple Motion?
Nick Meyers
on Jun 19, 2014 at 1:12:32 pm
a few points:
- rendering will pf course help.
- in your sequence settings, Video Processing tab, set Motion Filtering Quality to Best.
- use the de-flicker filter on the text
nick
Oscar Gotti
on Jun 22, 2014 at 12:15:05 pm
Thanks Nick but that doesn't seem to work.
I can find the "Flicker Filter" but not a "De-Flicker" filter, are they both the same?
M
Nick Meyers
on Jun 22, 2014 at 12:58:31 pm
my mistake,
yes, i think of it as the de-flicker filter as that's what it does,
it doesn't add flicker!
nick
