FCP sequence was DVCPRO 1280 x 1080..29.97…Need to output for computer playback and internet posting..
James Dow
on Jun 10, 2014 at 10:37:07 pm
What export settings should I use to make this look as good as possible? I usually work in DVCPro 720 at 24P but I was provided with footage that was 1920 x 1080..and I screwed up my sequence. the edit looked good in FCP but my export looked funky, almost square shaped. What should I do?
Thanks in advance,
JPD
JPD
Shane Ross
Re: FCP sequence was DVCPRO 1280 x 1080..29.97…Need to output for computer playback and internet posting..
on Jun 10, 2014 at 11:18:57 pm
What are your sequence settings? Is the sequence interlaced? Does the frame rate match the DVCPRO HD footage? 1920x1080 isn't square...it's 16:9.
Shane
Little Frog Post
James Dow
on Jun 12, 2014 at 3:56:12 pm
It was the 1280x1080 that was looking funky.
JPD
