GTX 680 Mac Edition or Sapphire HD 7950
Jim Murphy
on Jun 8, 2014 at 3:51:39 pm
Upgrading my GPU... can't decide on which to go with.... the GTX 680 Mac Edition or the Sapphire HD 7950. Running a 2010 Mac Pro 5,1, 32g Ram, Final Cut 10.1 and Mavericks.
Most of my work is done in Final Cut 10.1/Motion/Comprssor.
Which card will I get the most benefit out of?
Jim
2010 Mac Pro 5,1 - 32g Ram
FCP 10.1, Mavericks
Edwin Street
Re: GTX 680 Mac Edition or Sapphire HD 7950
on Jun 11, 2014 at 6:13:34 am
This is a great question but probably not the best place for it. Try the MacRumours forum under Mac Pro here: http://forums.macrumors.com/forumdisplay.php?f=1
I'm thinking about getting the 680 for my Mid2010 MacPro just because I've read in a lot of places it performs faster, but not by much.
At http://www.videocardbenchmark.net/high_end_gpus.html you can see the Sapphire 7950 comes in at 4645 points whereas the GTX680 comes in at 5716 points.
Either way they're both a great upgrade from the stock 5770/5870.
Jim Murphy
on Jun 11, 2014 at 12:58:00 pm
The price difference is quite a bit between the two and I'm wondering if the slight difference is speed is worth it. I mainly use FCPX, Motion and Compressor so the Cuda feature on the GTX680 won't give me a lot of benefit based on the apps I use.
What I have decided to do is give the 7950 a shot, and I am adding a Matrox Compress HD card to help speed up my h.264 processing to try and keep my machine and as responsive as possible.
Jim
FCP 10.1, Mavericks
Edwin Street
on Jun 11, 2014 at 1:23:04 pm
What exactly does the Cuda feature on the GTX680 do?
If you buy it through http://www.macsales.com you can get a rebate if you send them your old 5770/5870.
Do you know of other ways of speeding up the FCP7 rendering and exporting time?
Jim Murphy
on Jun 11, 2014 at 1:29:44 pm
From what I understand, CUDA is a programming method that specifically uses the power of the GPU. Adobe apps are written to take advantage of Cuda enabled GPUs where Apple apps like Final cut and Motion are written using the OpenCl method. It's not to say that OpenCl apps cannot harness the power of the GPU but Cuda is written specifically for that.
If I am incorret, please someone correct me.
Jim
FCP 10.1, Mavericks
Edwin Street
on Jun 11, 2014 at 6:42:03 am
Also take into account that the GTX680 is an extra $200 than the Sapphire HD 7950 on http://www.macsales.com
http://eshop.macsales.com/Search/Search.cfm?Ntk=Primary&Ns=P_Popularity%7c1...
