MP4 conversion using VBR 2 Pass
James Fox
on Jun 5, 2014 at 4:52:48 pm
Hi
Have been asked to convert a video to these settings:
Video
Container: mp4
Codec: h264
1920x1080 Progressive (Deinterlaced)
Frame rate: 25fps
VBR 2 Pass
Average bit rate: 2.2 mbps
Max bit rate: 2.5 mbps
Profile: Main
Keyframe: every 25 frames
Audio
AAC
256 kbps
High Quality
Is this possible through FCP or compressor? Struggling to find a setting to do VBR
Edwin Street
Re: MP4 conversion using VBR 2 Pass
on Jun 8, 2014 at 4:01:47 pm
Yes use Compressor to do this. It's fairly simple and it makes it easier that you know what you want.
If you don't want to buy Compressor 4 then Quicktime 7 or MPEG Streamclip will do the job.
