Blu Ray burned in FCP 7 will not play in Duplicator
Dean Longfield
on Jun 4, 2014 at 1:16:08 pm
I burned a Blu Ray in FCP 7 by using Share, with the Burn a Blu Ray box checked. The Blu Ray disc plays back fine in Blu Ray players but my client's duplicator is not accepting the disc.
Can a Blu Ray that was made directly from FCP 7 > Share be duplicated?
Thanks.
Mark Suszko
Re: Blu Ray burned in FCP 7 will not play in Duplicator
on Jun 4, 2014 at 1:39:25 pm
Stupid question, but we have to eliminate the obvious first: is the duplicator Blu-Ray capable, and has it been used successfully to make a BD dub before?
Mark Suszko
on Jun 4, 2014 at 1:43:10 pm
Jinx, Shane owes me a soda.
Shane Ross
on Jun 4, 2014 at 1:44:04 pm
Gah! :)
Specifically a Coke.
Shane
Little Frog Post
Shane Ross
on Jun 4, 2014 at 1:40:09 pm
It's a BluRay duplicator, right? Not a DVD Duplicator?
Shane
Little Frog Post
Dean Longfield
on Jun 4, 2014 at 2:08:17 pm
Correct. A Blu Ray Duplicator. Specifically a Pioneer BDR-XD05W
Dean Longfield
on Jun 4, 2014 at 2:55:43 pm
Here's what I'm doing:
Bring HD footage into FCP 7. (Have tried both XDCAM & AVCCAM footage).
I send said footage to Share and check the Burn a Blu Ray box.
A Blue Ray is burned on a Pioneer BDR XD05W Blu Ray Burner.
The Blu Ray plays back fine on Blu Ray players BUT it will NOT play back in my client's Blu Ray Duplicator.
I Think: It's either a Hardware compatability issue OR
A File Writing issue.
Has anyone made a blu ray using SHARE directly in FCP7 and then brought that disc into a Duplicator unit and successfully made copies???
Please let me know. Thanks, I appreciate your taking the time to respond.
Mark Suszko
on Jun 4, 2014 at 2:57:15 pm
OK, well, these things are rarely simple to pin down, but the simplified, "share" type of BD burn you can do from the FCP timeline is perhaps not as rigorous an ISO standard as if it were authored in DVDSP or Encore.
And your duplication system is a bit more demanding. I'd next try a BD made from exporting a self-contained version off the timeline and bringing that into DVDSP, then try making a dub master from DVDSP to see if that works.
Mark Suszko
on Jun 4, 2014 at 3:02:00 pm
One other thought; the duplicator may think your disk is region-limited or copy-guarded. Check any settings for those two features. My hunch is that something in the lead-in header information of your master is causing the issue. You might also want to try the first thing you did, but with a different brand of blank media. That's a long shot, but sometimes it pays off.
Dean Longfield
on Jun 4, 2014 at 4:09:22 pm
Mark,
may I ask where the settings are for those features? am out of the studio right now so I can't see it in front of me..... if you know off the top of your head... Thanks !!
Dean Longfield
on Jun 4, 2014 at 3:22:47 pm
>> I'd next try a BD made from exporting a self-contained version off the >timeline and bringing that into DVDSP, then try making a dub master >from DVDSP to see if that works
Thanks for your reply.
If I did what you suggest wouldn't that make a DVD and not a Blu Ray?
Mark Suszko
on Jun 4, 2014 at 6:59:17 pm
My bad: I was thinking DVDSP could do BD, forgetting it was made to be able to to the now-defunct HD-DVD. So I'm down to suggesting Adobe Encore now.
Dean Longfield
on Jun 4, 2014 at 7:52:24 pm
OK Thanks. Will try Adobe Encore.
Roger Poole
on Jun 6, 2014 at 12:15:37 am
Excuse me diving in here. I never went down the route of Blu-ray duplication but is this a license issue. My understanding is that you need to pay Sony a ridiculously expensive license fee to enable duplication. The duplicator looks on the BDR data for the license, if none found, no dupes. Probably the main reason Blu ray didn't enjoy the success that it should.
