Audio sample rate question
Oscar Gotti
on May 31, 2014 at 7:46:22 pm
Hello,
I was recently told to always convert all audio to 48 khz before editing on FCP 7. My question is, can't I just import the 44.1 khz audio into a 48 khz timeline on FCP? Doesn't that do the same thing? I have done that in the past and haven't encountered any problems...
Also, will there be any problems if I upload a 44.1 khz music video clip into YouTube?
M
Andrew Rendell
Re: Audio sample rate question
on Jun 1, 2014 at 1:18:26 pm
You can import the 44.1kHz audio, it will work but I would advise against it because on the occasions that I have I've had sync issues - slippage between the positioning on the track and the timing of the playback, so that where the vision is supposed to be matched to the music it goes slightly out (sometimes quite a long way out if I have several audio tracks at that point).
