• | Best Compression App?
on May 20, 2014 at 4:21:26 pm |
I've tried PAVTUBE, ProxyMill and a few others and all seem to have their own problems compressing and delivering what I need, simple things like recovering time code from original file.
Whats a good fast compression software for Sony EX1 Camera BPAV files, GoPro MP4, Sony FS700 AVCHD to compress ProResLT, with original file name, TimeCode.
Michael Harrington
Mac Pro, Dual Quad-Core Intel Xeon 2.66 GHz, 12 GB, FCP7, Mavrick, ATI Radeon HD 4870, 30-inch Cine Display, 4 - 1TB internal, G Speed 6TB Raid 5, 1.25TB Esata, Numerous FW 800 external drives, Matrox MX02Max, FSI 17" Broadcast Monitor, Black Magic Mini Sync Generator, Mackie 1402 & Event 20/20 monitors.
• | Re: Best Compression App? on May 20, 2014 at 4:39:15 pm |
• | Re: Best Compression App? on May 20, 2014 at 4:46:02 pm |
I can't afford Episode and I've tried a few $39 - $200 including ProxyMill but ran in to problems working with FCP 7 in 10.6.8, strange problems that make the developer scratch his head.
I'm a week behind and need a good solid solution that will include timecode, import properly in to FCP 7 on 10.6.8, may upgrade osx to 10.8.6 as recommended by those still using FCP 7.
Michael Harrington
• | Re: Best Compression App? on May 20, 2014 at 7:22:50 pm |
MPEG Streamclip has never failed me!
• | Re: Best Compression App? on May 20, 2014 at 8:46:04 pm |
MPEG STREAMCLIP doesn't work with MXF nor AVCHD...
Shane
Little Frog Post
Read my blog,
Little Frog in High Def
• | Re: Best Compression App? on May 20, 2014 at 8:46:51 pm |
Woops.
Sorry all. Read the original post wrong.
• | Re: Best Compression App? on May 21, 2014 at 5:42:34 pm |
There isn't, that I've been able to find, one best program. I use a combination of Apple Compressor, DaVinci Resolve and After Effects. (and every once in a while, Sorenson Squeeze and Adobe Media Encoder). And when it's easier, Log and Transfer or batch export in FCP 7. Some of these are slow and it's best to leave a batch running overnight. Resolve has a bit of a learning curve but is surprisingly capable with the inclusion of LUTs and can be quite fast with the proper set up.
