grey lines/blocks when exporting
Molly Snyder Fink
on May 16, 2014 at 9:02:56 pm
I have been exporting from FCP and Quicktime player and getting grey blocks across the video or photo.
I have older versions of things: FCP7, quicktime player 7.6.9 and my OS is 10.5.8 on a macbook pro laptop.
My video however is Calibrated DVCProHD 720p60 Integer Little Endian (it was exported from FCP) and I put it back into FCP to do export or do export from QT player. Either way, I get the grey blocks/or lines.
I'm not able to update to proappsqtcodecs because of my OS.
Shane Ross
Re: grey lines/blocks when exporting
on May 16, 2014 at 10:06:12 pm
[Molly Snyder Fink] "My video however is Calibrated DVCProHD 720p60 Integer Little Endian"
Calibrated DVCPRO HD? You mean you are editing MXF native using the Calibrated software?
Shane
Little Frog Post
Molly Snyder Fink
on May 16, 2014 at 10:20:15 pm
unsure. I have a QT file with the settings I specified. I then bring into FCP and do export. and that is when the grey lines show up. hope that helps...
Shane Ross
on May 17, 2014 at 6:17:52 pm
Try making a new sequence...ProRes settings. Copy and paste into that sequence...render. then export.
Shane
Little Frog Post
