Choosing a Format and Editing Work Flow for a Grade 3 and 4 Class Movie
John Hepworth
on May 13, 2014 at 3:21:36 pm
As the dad who edits, I've been enlisted to help my son's class make a movie.
Can anyone suggest the EASIEST workflow as we will likely have footage from ALL sorts of cameras...from iPhones/iPods to semi professional.
I imagine what we'll have to do is settle on a standard file format XD-CAM? Pro-Res? and then create a compressor droplet or MPEG streamclip preset so everyone can turn their footage into the same format.
Any thoughts/commiseration welcome.
John Hepworth
Mark Suszko
Re: Choosing a Format and Editing Work Flow for a Grade 3 and 4 Class Movie
on May 13, 2014 at 4:26:00 pm
It would be nice if each camera user did their own format conversion, say, using the free MPEG Streamclip, to standardize with. FCP7 likes ProRes, but you could also use DVCProHD setting.
Shane Ross
on May 13, 2014 at 8:06:18 pm
If I were doing this, I wouldn't put the burden of converting onto the other parents. Most likely they won't have a clue how to do this. Some barely have computers. Get the raw files from them and do it yourself. IMHO.
Hopefully you have a clue what you are doing. :)
Shane
Little Frog Post
John Hepworth
on May 13, 2014 at 8:08:49 pm
Yes that's what I ended up doing for the grade 2 movie...
This time the kids want to do the editing - so I'm trying to decide on the best format to convert everything into.
So will most likely collect all the footage, convert it into a standard format, and redistribute it to the 'editors'.
thanks
John
David Roth Weiss
on May 15, 2014 at 1:18:13 am
[John Hepworth] "Can anyone suggest the EASIEST workflow as we will likely have footage from ALL sorts of cameras...from iPhones/iPods to semi professional."
Yes, I can answer your question with two words, "Adobe Premiere."
David Roth Weiss
ProMax Systems
Burbank
DRW@ProMax.com
Sales | Integration | Support
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
