Bitrate problem on Compressor.
Oscar Gotti
on May 2, 2014 at 8:53:07 pm
Hello,
I am trying to compress a .mov file to a .mp4 primed for Vimeo.
I am trying to adhere to Vimeo's guidelines, which state that a 1280x720 video should ideally be 5,000 to 10,000 kbit/s. (https://vimeo.com/help/compression)
Now, when I send my video to Apple Compressor, and use the MP4 setting, it seems the maximum kbps is 2048 when i choose the 'constant' option. It does not state the bitrate when I choose the "High VBR" option however...
Why can it not got higher when I choose the constant option?
The original video is Apple Pro Res 422 and is 2.38GB.
Mayto
Chris Babbitt
Re: Bitrate problem on Compressor.
on May 3, 2014 at 3:04:04 pm
Instead of using the Mp4 setting, go to Quicktime settings and choose H.264. There you will find the settings you need.
