Fragmented files after export.
Valerie Marinho
on May 2, 2014 at 4:53:54 pm
Hi everybody,
My problem : on FC7, the quicktime export to create my master is fragmented in one .mov and several -av (?), each 4.1 Go. (My Hard Drive is not in fat32). And the .mov can be read only for 5 mns (my film is about 70mns).
Can anyone has a solution ?
Thanks in advance,
Valerie
Shane Ross
Re: Fragmented files after export.
on May 2, 2014 at 5:05:37 pm
How is the drive formatted, if not Fat32? How did you export? File>Export>Quicktime Movie? Self contained...other settings?
Shane
Little Frog Post
Valerie Marinho
on May 2, 2014 at 5:23:43 pm
Thanks for your answer,
The external hard drive is formated in mac Os extended.
The export : file-export-quicktime sequence. No conversion, i want to have a master via quicktime, not a compressed file.
Other settings, the quicktime export is set on apple pro res 422 (hq)
Excuse my bad english, i'm in Paris, France ...
Shane Ross
on May 2, 2014 at 6:05:40 pm
Is this drive also set up as your Capture Scratch drive? In the Final Cut Pro System Settings...in the SCRATCH DISKS tab....at the bottom. Do you have CAPTURE LIMIT/FILE EXPORT size checked? And is it set to 4000 or so MB?
Shane
Little Frog Post
Valerie Marinho
on May 2, 2014 at 6:43:37 pm
Yes, it is the same drive and the Scratc setting is notched on 4000 MB.
Do i un notch it ?
Shane Ross
on May 2, 2014 at 7:32:21 pm
Yep! Don't ever have that notched.
Shane
Little Frog Post
Valerie Marinho
on May 2, 2014 at 7:51:02 pm
Ok, thanks Shane,
I do that and make another export right away.
I cross my fingers and i'll let you know after the export !
Thanks again
Valerie Marinho
on May 2, 2014 at 9:46:18 pm
Thanks Shane,
I did un notch the CAPTURE LIMIT/FILE EXPORT and my export is just perfect and in one piece !
Thanks again
