Unable to Initialize Capture Device
Scott Maida
on May 2, 2014 at 3:36:06 am
I received this message when trying to L and C from my external drive with files from a DSLR camera (i'm pretty sure it was a Canon but can find out if it matters)
Device is not connected or the capture preset is not setup correctly. You may still log offline clips.
This might also happen if you play DV footage in an HDV device.
Never happened before. however, I did have trouble with a scratch drive setting when I opened the FCP program.
Suggestions?
Shane Ross
Re: Unable to Initialize Capture Device
on May 2, 2014 at 4:00:19 am
Log and CAPTURE is used when capturing from TAPE sources. DSLRs are tapeless. You need to use Log and TRANSFER
Shane
Little Frog Post
Scott Maida
on May 2, 2014 at 4:23:03 am
Brain freeze! Thanks for thawing it out.
however, now that I'm in L and T, shouldn't I be able to see the files in the window to begin the transfer or am I missing a step?
I'm tired and will attack this tomorrow but these may be AVCHD files from a DSLR
Shane Ross
on May 2, 2014 at 4:31:48 am
Which DSLR? Canon requires a Log and Transfer plugin to be installed. Some Panasonic ones shoot AVCHD that are compatible with L&T...depends
Shane
Little Frog Post
Scott Maida
on May 2, 2014 at 1:17:53 pm
I'm trying to find out what camera was used.
meanwhile, some old folders show up when I open Log and Transfer.. not the new drive.
and can I import into imovie, edit a rough and export into fcp?
Scott Maida
on May 2, 2014 at 1:31:39 pm
it's a canon 100 camera
Scott Maida
on May 3, 2014 at 12:01:47 am
I got it figured out... with the help of the videographer. I"m rusty.
but thanks for the suggestions!
Mark Suszko
on May 2, 2014 at 1:52:27 pm
Do not use imovie for this.
Scott Maida
on May 2, 2014 at 5:51:46 pm
I got help from someone. I was missing a simple step. Figures.
Thanks for your help!
