Stabilizing problem
Paula Zimmerman
Stabilizing problem
on Apr 30, 2014 at 8:55:52 pm
I've worked through this clip with 5 different stabilizers-SmoothCam, Lock & Load, After Effects stabilizer, Mocha, and iStabilize and I get almost no change. I've read tutorials and tried everything I can find and I still get very little improvement. I've included a portion here- http://reels.creativecow.net/film/first-shot-testmov Any advice you can offer is greatly appreciated. Thank you for your time and help.
Mark Suszko
Re: Stabilizing problem
on Apr 30, 2014 at 9:45:14 pm
Try stabilizing it in Apple Motion using the standard 2-d tracker?
Brooks Tomlinson
on May 1, 2014 at 5:35:48 am
Well, you have a fixed object (you subject) that never goes off screen. It shouldn't be that hard to stabilize. Although, the best result you can hope for is a zoomed in image. Since it moves a fair amount. Did you try in after effect changing the warp stabilizer to position data only?
Brooks Tomlinson
"I dream in 32bit float"
