Lost some video filter effects
Yama Rose
on Apr 17, 2014 at 2:14:54 am
Dear Creative Cows,
I have searched high and low through the forums but have yet to find a solution. I am in the process of learning a FCP lesson woefully late, as I moved some video files around (and deleted what I thought were worthless others) a few weeks ago. I thought I was organizing things - little did I know. I have run into several problems since then.
The current issue is that some of my clips were edited with the Bad TV video filter. If I play the timeline everything is fine and the effect is shown. However, if I try to modify a clip it goes red and I get the message >Can't locate effect: Bad TV< When I tried to find the effect to just reapply it, I realized to my great horror and consternation that it is no longer there. I have no idea what I've done and if I've inadvertently deleted other effects in the meanwhile as well. How can I restore?
Thank you!
YR
Mark Suszko
Re: Lost some video filter effects
on Apr 17, 2014 at 2:56:19 pm
If you're lucky, you just moved it out of the folder where it was supposed to be. if you're unlucky, you'll have to re-load the FCS3 suite. First, go check if the effect is still there and working in Apple Motion.
Yama Rose
on Apr 19, 2014 at 11:51:07 am
Dear Mark,
Thanks so much for your help.
I believe that I am unlucky. If I reinstall FCP will the effect return? Also, just to cross my ts, if I reinstall FCP, none of my video files/projects will suffer, correct?
YR
Mark Suszko
on Apr 19, 2014 at 2:53:55 pm
No warranty should be inferred or implied: I make no guarantees. Be sure to save your fcp project files and your media to another drive first.
Yama Rose
on May 1, 2014 at 4:52:59 pm
Hi again Mark,
Just wanted to confirm that after uninstalling and reinstalling the effects returned, with no file cannibalism. Thanks for your help.
YR
Mark Suszko
on May 1, 2014 at 5:36:23 pm
Best news I've had so far today:-)
