NTSC DVD need to rip & re-edit in FCP... then re-deliver on PAL DVD - Best process?
Ashley Edwards
on Apr 9, 2014 at 4:03:16 pm
Hi guys,
A client from the US has sent me an NTSC DVD of rushes from a birthday party. The client wants me to rip the DVD, re-edit the material then deliver a PAL DVD to their family in the UK.
I've ripped the DVD using Handbrake - giving me a JVT/AVC coding format MP4 at 720 x 480 (853 x 480) at 25FPS ...which looks fine in QT... but I've tried dropping it into FCP and then exporting the timeline as an editable format like ProRes or DV-PAL but it just doesn't look as good as the original file.
Anyone have any ideas of the best way to go about this or where I'm going wrong?
Many thanks in advance...
Greg Ball
Re: NTSC DVD need to rip & re-edit in FCP... then re-deliver on PAL DVD - Best process?
on Apr 9, 2014 at 5:12:18 pm
Hi Ashley,
You can't edit MP4 files in FCP. You need to convert them to ProRes before you edit. Try using mpeg streamclip to convert the files into an editable file.
Good luck.
