Why do subtitles bounce on playback?
Noam Osband
on Apr 4, 2014 at 3:51:48 am
Sometimes, if I play with subtitles, when I play them back in the canvas, they might bounce around or seem to jump from one spot to the other.
But when I export the sequence they are not doing that and instead they are static like they should be.
Why does it get a bit janky on playback? It's annoying cause I think there is a problem and then I need to export a small movie file to discover there is not.
Thought?
thanks in advance,
noam
Nick Meyers
Re: Why do subtitles bounce on playback?
on Apr 4, 2014 at 1:39:27 pm
what subtitle generator are you using?
i have noticed this with Text Up Pro.
sometimes if the underlying clip has a motion effect, the sub jumps up a few lines.
solution is to render.
nick
Noam Osband
on Apr 5, 2014 at 6:01:11 am
Yeah, I'm totally using that text generator.
Good to know! Thanks for the quick and useful answer!
