Generate list with all used media with path in FCP?
Karel Voners
on Apr 1, 2014 at 11:29:32 am
Is there a way to generate a list of all referenced media from an entire project in FPC?
Cheers!
Karel.
Shane Ross
Re: Generate list with all used media with path in FCP?
on Apr 1, 2014 at 5:01:03 pm
All media referenced in a sequence?
Sure...The free way is to export an EDL and wade thru all the extraneous data...or use my favorite footage reporting app, SEQUENCE CLIP REPORTER:
http://assistedediting.intelligentassistance.com/SequenceClipReporter/
Shane
Little Frog Post
Nick Meyers
on Apr 4, 2014 at 1:44:19 pm
Another way is to copy the sequence into a new project,
and got to the Tool Menu > Create Master Clips
you will get one instance of each clip used.
after a bit of tidying up of text generators and slugs etc, you can generate a batch list
very basic, not as detailed as Sequence Clip reporter
nick
