bouncing two clipsin one without losing dimensions
alex gat
on Apr 1, 2014 at 8:35:21 am
Hello,
I have a problem.
I have a clip that I have scaled and moved to correct a bad frame.
On this clip, I have a sudden movement that I have corrected using speed.
For that I have split the clip in two portions, one of which is now slowed down.
The final touch is to add a smooth cam. The problem is that the effect acts differentely on both clips creating a bump when jumping from one clip to the other.
Usually I bounce the clips before adding the smooth cam but as my clips are already scaled I don't need the smoothcam to scale them again.
But if I bounce before adding the smoothcam, I loose the opportunity to avoid rescaling because when bouncing I loose the off frame portion of my clips.
Thus my question :
can I bounce without losing the original dimensions of the clips ?
I guess I could do the following :
- first smooth cam
- second correct speed
- third correct scale and frame
Yes, sure next time that what is I will do, but I don't want to do it all over again.
Any suggestion ?
Steve Eisen
Re: bouncing two clipsin one without losing dimensions
on Apr 1, 2014 at 2:17:54 pm
Your smoothcam is automatically adding movement on your clip. You really need to do this outside of FCP. After Effects or Motion may help.
Fixing in post is a bitch!
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
Dave LaRonde
on Apr 1, 2014 at 4:16:43 pm
Here's another vote for using an application other than FCP for the fix. As Mr. Eisen writes, either Motion or After effects are better suited for doing this.
Dave LaRonde
Promotion Producer
