Pro res in dv timeline
Hunter O'Shea
on Mar 30, 2014 at 9:16:04 pm
Hi! I'm working on a dv NTSC timeline and I'm using files recorded on my canon t3i that have been converted from h264 files to apple prores. Problem is when I burn a DVD of the project the dslr clips look strobey in comparison to the dv clips. Is this because they're are progressive and not interlaced like the majority of files in the timeline? Should I interlace the pro res files? Any help is appreciated!
-Hunter
Shane Ross
Re: Pro res in dv timeline
on Mar 31, 2014 at 5:08:14 pm
What frame rate is the Canon DSLR footage?
Shane
Little Frog Post
Hunter O'Shea
on Mar 31, 2014 at 9:36:10 pm
30 fps
Shane Ross
on Mar 31, 2014 at 9:46:12 pm
It might look choppier, because it isn't interlaced, where DV is. Interlaced makes for smoother motion.
Shane
Little Frog Post
Hunter O'Shea
on Mar 31, 2014 at 11:40:02 pm
So I should interlace the progressive clips for an interlaced timeline. Mpeg streamclip has an interlace scaling feature would this work?
