FCP 7 editing sequence settings: XDCAM EX or apple pro res?
Steve Coulson
on Mar 26, 2014 at 3:55:31 pm
Hi all: When I first starting cutting xdcam ex 50i footage, I found advice to use one of the apple pro res settings for my sequence. I did that initially, but now I am using the XDCAM EX 50i settings to edit. I think that's because apple is now supporting the xdcam ex codec. But perhaps FCP always has.
Anyway, I do incorporate a wide variety of video formats in my xdcam ex timelines and occasionally have issues such as the video output freezing or the audio playing but no video display.
Would I see a visual improvement with apple pro res or would one of those pro res settings make my system more stable or anything?
Or should I continue using XDCAM ex?
Thanks for you time
Steve
Sascha Engel
Re: FCP 7 editing sequence settings: XDCAM EX or apple pro res?
on Mar 26, 2014 at 4:15:27 pm
I'd definitely go for the ProRes settings, specially if you mix different codecs and sizes.
Way more stable.
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikang
Bret Williams
on Mar 26, 2014 at 4:54:07 pm
You can set the sequence to XDCam EX, but set the render to ProRes if I remember correctly. That way native footage doesn't require rendering, but anything added that isn't XDCam is rendered as ProRes. Best of both worlds.
Sascha Engel
on Mar 26, 2014 at 4:58:47 pm
Yup, that pretty much sums it up.
Sascha Engel
