External video not allowed
Mike Maloney
on Mar 25, 2014 at 5:04:01 pm
For some reason, I cannot actuate the external video command on FCP7. I'll do the pull down menu, punch "view all frames" then when I release it, it defaults back to "none". I've tried opening a new project, etc., but it still "won't stick".
Any suggestions?
Mike Maloney
Mike Maloney
Maloney Marketing Group
maloneymarketinggroup.com
beartoothrecording.com
mmg.bz
Shane Ross
Re: External video not allowed
on Mar 25, 2014 at 5:40:28 pm
What IO device/card are you using?
Shane
Little Frog Post
Mike Maloney
on Mar 25, 2014 at 6:19:30 pm
I am not using a card. It's an iMac. I'm using an AJA T-tap with Thunderbolt.
Mike Maloney
mmg.bz
Steve Eisen
on Mar 25, 2014 at 6:24:24 pm
With a combination of your NLE and AJA Control panel. Choose the correct settings and you'll be up and running.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
Shane Ross
on Mar 25, 2014 at 6:27:23 pm
I said "IO Device/Card." The T-TAP is an IO device. :)
OK then. Did you choose an AJA VIDEO OUT setting? Or Easy Setup?
Shane
Little Frog Post
Mike Maloney
on Mar 25, 2014 at 6:32:01 pm
In my exuberance to get up and rolling, I just connected the device, but conveniently overlooked the instructions to install the software.
Thanks for grounding me back to reality. LOL.
Mike Maloney
Mike Maloney
mmg.bz
