Final Cut Pro
Aboud Orfali
Final Cut Pro
on Mar 19, 2014 at 7:11:14 am
Good day;
I have the following configuration : Apple Mac Pro (12 Cores /2.66 GHz/ 12 GB RAM /Snow Leopard OSX / G Speed es Pro ( Mini SAS connectivity 8TB /RAID 0/AJA KONA 3G Card with Break out Box /Final cut Pro 7/HD Footage).
The problem :
- Dropped frames.
- Lipsing
Please note that I have another system identical to the previews , in which I do not encounter any of the above mentioned problems.
Will any one help please .
Thank you
Aboud
Mark Suszko
Re: Final Cut Pro
on Mar 19, 2014 at 1:25:49 pm
If you truly have identical twin systems, what I suggest is trading cables, drives, and other parts between the "good" one and "bad" one, one thing at a time, and seeing what changes.But my guess is going to be either a RAID problem or a video card problem. Start with swapping cables, as that is the easiest and cheapest thing to try first.
Aboud Orfali
Re: Final Cut Pro
on Mar 19, 2014 at 2:13:26 pm
Thank you for your reply. I will try this and return to you .
Aboud Orfali
Re: Final Cut Pro
on Apr 6, 2014 at 11:54:57 am
Hello again ..
I have tried replacing different parts from the cables and still getting the same result;in addition i am now having a (lipsing) problem which occurred several times on different locations of the time frame . Any ideas ?? Thank you for all the help & support .
Mark Suszko
Re: Final Cut Pro
on Apr 6, 2014 at 1:49:04 pm
Did you swap the video cards yet?
Aboud Orfali
Re: Final Cut Pro
on Apr 7, 2014 at 6:04:34 am
Yes I swapped the video cards and all the cables one by one and still get the same result.
Thank you
