Importing MP4 from JVC GY-HM750 into FCP
Andrew Marchand
on Mar 11, 2014 at 1:45:54 am
I'm having a heck of a time figuring this out.
The settings on my JVC Camera got changed. I was probably messing with them, and switched my recording from QuickTime to MP4 and this has caused a bit of a problem for me.
When I was recording in QuickTime it was no issue to Log and Transfer everything into FCP so that I could edit it. However now that I've recorded something in MP4 it will not recognize the folder wrappers at all, no matter how much I try.
It's currently wrapped like this.
Robotis->Private->JVC->BPAV->CLPR, CUEUP.XML, MEDIAPRO.XML, TAKR->From there, every clip is wrapped individually and contains:
059G1035_01.MP4
059G1035_01.SMI
059G1035_01|01.PPN
059G1035_01M01.XML
059G1035_01R01.BIM
I can't for the life of me figure out how to get any of these into finalcut. Nothing I've tried has worked. Is there any solution to this?
Dave Farrants
Re: Importing MP4 from JVC GY-HM750 into FCP
on Mar 11, 2014 at 5:29:19 pm
No need to re-shoot! - I had a cameraman give me a card recently from a JVC700 with .mp4 files. You just need to put all the .mp4 files into one folder then use IFFMpeg ($23) to batch convert to ProRes. You'll also need FFMpeg (free) installed.
Web - http://www.foxvideo.co.uk
Blog - http://foxvidpro.blogspot.co.uk/
