FInal Cut 7 suddenly keeps putting in frames during edit of other parts
alex wright
on Mar 2, 2014 at 12:10:57 am
for some reason my final cut 7 has started putting in frames infront of my clips??
i'm cutting up various films i've worked on to create a show reel but even though i know i'm on the right frame, and even if i go further into the clip to be sure and the time line shows it fine when i play back my timeline when the next clip starts it will randomly put in a frame from the last clip that would have come before it in the film?
i've racked my brain and just have no explanation or way to fix this..
any suggestions/help would be greatly appreciated as i'm at a loss.
i even uninstalled my copy of final cut stuido and reinstalled it hoping that would somehow fix the problem but it's still doing it.
thanks
Shane Ross
Re: FInal Cut 7 suddenly keeps putting in frames during edit of other parts
on Mar 2, 2014 at 1:17:18 am
What is the codec of these various films? Did you convert them to editing codecs?
Shane
Little Frog Post
