Pluraleyes 3 shuts down when creating new project from FCP 7
Charles Dente
on Feb 24, 2014 at 11:24:31 pm
Hi there,
Im currently working on a project with multiple cameras and audio tracks that I need to link together. I use Pluraleyes 3 a lot but for some reason with this project when I send a sequence to pluraleyes I get the message
"The application has encountered an unexpected problem.
You may continue, but the application may be unstable."
i continue but then the program quits unexpectedly. Is there anything I can do to fix this issue?
Charles
James Morton
Re: Pluraleyes 3 shuts down when creating new project from FCP 7
on Feb 24, 2015 at 4:32:42 pm
Hi Charles,
I'm having the exact same problem. Did you manage to solve it in the end?
James
