Compressor frame controls
Bleakley McDowell
on Feb 23, 2014 at 12:47:21 am
I'm converting some SD 720x480 29.97 footage to HD 1440x1080 23.98 in Compressor.
Under video settings on the "encoder" tab I've set a custom frame rate of 23.976, which I read on this forum was the best thing to do.
So, on the "frame controls" tab under 'set duration to' I'm not sure what to choose.
The default is "100.000% of source", but I can also choose a variety of different frame rates or choose "so source frames play at 23.98 fps"
What should I choose? Just leave it at the default of 100% of source?
Shane Ross
Re: Compressor frame controls
on Feb 23, 2014 at 2:53:36 am
Leave it as 100% of source. You don't want to speed it up, nor slow it down. But keep it the same duration.
Shane
Little Frog Post
Bleakley McDowell
on Feb 23, 2014 at 3:08:13 am
