ProRes 4444 to DVD
Karlo Gorup
ProRes 4444 to DVD
on Feb 20, 2014 at 2:34:58 pm
Hello!
I have to make a DVD out of a sequence edited in FCP7 in ProRes4444. Does anyone know what is the best way to do it?
I exported the reference of the sequence (I did not check "make movie self contained") and just put it in the toast Titanium 10, but the quality is not really good. Is there a better way to do it?
Shane Ross
Re: ProRes 4444 to DVD
on Feb 20, 2014 at 5:00:28 pm
DVDs are SD...not HD. You'll need to author a BluRay in order to get HD. For that you will need a BluRay burner, BluRay media...but you can still use Toast.
Shane
Little Frog Post
Karlo Gorup
on Feb 21, 2014 at 10:32:07 am
OK, thanks!
I got blu ray burner and blu ray media, is it ok to put the reference of the sequence as I did for the standard DVD, or should I do it in some other way?
Shane Ross
on Feb 21, 2014 at 5:04:18 pm
Sorry, I haven't used Toast nor burned a BluRay. I just know what to use to do it.
Shane
Little Frog Post
Karlo Gorup
on Feb 21, 2014 at 5:06:03 pm
Thank you anyway!
