 | Multiple Audio track export and Import question.
on Feb 14, 2014 at 2:06:53 am |
Hi I have just received my dual mono audio splits for my project. I am able to export the multi track qt but when I reimport the clip to check the work any track I panned L or R are back to center. Does any one know why the new clip does not retain the panning? I have the sequence settings > audio outputs > set to dual mono. Everything is on the correct track so I thought I had everything set correctly.
Thanks for the help
 | Re: Multiple Audio track export and Import question. on Feb 14, 2014 at 7:20:55 am |
You said it yourself...you have the sequence set to dual mono. If you want it panned, make it stereo.
Shane
Little Frog Post
Read my blog,
Little Frog in High Def
