odd artifact caused by transition effects
Scott Henson
on Feb 13, 2014 at 6:11:31 pm
When adding any transitions between clips, be it a dissolve or push or wipe or anything (both FCP efx and third party transitions) I am getting a little "jump" in the video -- right at the point where the effect is done. So if it is a dissolve, as soon as the dissolve ends the video repeats a few frames and appears to "jump."
This is FCP 7.0.3 -- I am not using X yet. Imac running OSX 10.82. 3.06 GHz Intel core 2 duo.
If anyone has a suggestion I would appreciate it.
Thank you!
Shane Ross
Re: odd artifact caused by transition effects
on Feb 13, 2014 at 6:31:36 pm
What is the codec of this footage?
Shane
Little Frog Post
Scott Henson
on Feb 13, 2014 at 6:37:20 pm
H.264
Shane Ross
on Feb 13, 2014 at 7:11:37 pm
FCP doesn't work with H.264 with any reliability. You must convert the footage to ProRes 422 before working with it in FCP. And the sequence must also be ProRes 422. You can try a possible fix of changing the sequence setting to ProRes 422. That works for some things, but not all.
Shane
Little Frog Post
Scott Henson
on Feb 13, 2014 at 7:14:21 pm
Ah yes. Thank you so much!
Eric Quao
on Jun 24, 2014 at 3:41:49 pm
Scott and Shane,
Hello. I am a brand new member to the COW. Currently, I am having the same problem as well. However, I am a beginner in the editing field.
This is FCP 6.0.6 -- I am using X. MacBook OSX 10.6.8. 2.16 GHz Intel core 2 duo.
I shot the footage with a Canon T3 the codec is .mov
Would my issue have the same solution as Shane explained...please help...thanks
Eric Quao
Black Star Media
Shane Ross
on Jun 24, 2014 at 4:47:53 pm
[Eric Quao] "I shot the footage with a Canon T3 the codec is .mov"
You cannot edit the native format that camera shoots. YOu must convert it to ProRes. Compressor will do this...there are Presets for ProRes Progressive.
Shane
Little Frog Post
Eric Quao
on Jun 26, 2014 at 12:08:23 am
Shane,
Thanks for the response...does it matter if I use the high quality or regular...also will I have to compress all my clips whenever I us my t3...
Eric Quao
Eric Quao
on Jun 26, 2014 at 12:19:23 am
Shane,
As I mentioned previously...I am a beginner to editing...is there a book or book, or website other than than this site that can help me get better...
Eric Quao
