Three FCP audio filters suddenly greyed out
Phil Kurus
on Feb 8, 2014 at 12:40:59 am
FCP 7.0.3, Mavericks 10.9.1
Three FCP audio filters have suddenly gone grey. They appear in the drop-down menu, but are not selectable:
Low Shelf Filter
Notch Filter
Parametric Equalizer
All other audio filters are present and available.
I've repaired permissions.
I don't use FCP often enough these days to judge when these may have gone missing. The only recent change that I can recall is upgrading pro codecs about a week ago.
Ideas?
Shane Ross
Re: Three FCP audio filters suddenly greyed out
on Feb 8, 2014 at 12:55:59 am
Might be the Maverick's OS. It wasn't written with FCP 7 support in mind, so some things may not work like they did in older OS versions.
Shane
Little Frog Post
Phil Kurus
on Feb 9, 2014 at 5:17:24 pm
It may be Mavericks-related, but if so, why just those three SFX, not the entire bundle?
Luckily I've discovered that the effects are still available via the effects tabs--so they may be dragged and dropped onto clips. This is relatively cumbersome though.
Cheers.
John Fishback
on Feb 9, 2014 at 6:37:39 pm
Are the plugins in their proper folder? I don't remember where that is and I'm not at my edit computer to check. If they are missing try replacing them manually using the plugs from a working version.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
