P2 Material Final Cut does not import all files
Esther Hassfurther
on Feb 5, 2014 at 8:46:18 pm
First of all, I am not a native english speaker so I hope I don't have too many mistakes...
I have p2 mxf files as a source material. I have ALL the files (Contents, Lastclip, 6 folders inside) copied from the P2 card.
But when I log and transfer into final cut (exactly like in the tutorial) it won't open all the files but leave out some. Apparently the missing clips are always somewhere between clip 1 and 20.
Any Ideas?
Shane Ross
Re: P2 Material Final Cut does not import all files
on Feb 6, 2014 at 1:13:27 am
FCP will connect clips that are "spanned." Meaning the camera breaks up the shots into 4GB chunks. If you do long takes, one take might be 2 or more MXF files. FCP will join those MXF files and make one clip. SO you might have 20 files, but really only like 8 shots...it's broken up.
Is that the case, or is there footage missing...really?
Shane
Little Frog Post
Esther Hassfurther
on Feb 6, 2014 at 12:23:55 pm
Hi Shane!
I'm kinda embarrassed that I didn't see that...
Works perfectly, all the footage is there and actually I really appreciate that final cut merges the files together. I didn't like the idea anyway that they are broken up (I found that out before).
So thank you so much for being such a big help!
Esther
