Problem Codec
Andrew Cross
Problem Codec
on Feb 5, 2014 at 2:04:27 pm
Hi Guys,
Thanks in advance for all of your help.
I've received files that I cannot get to read in Log and Transfer or any other software.
The folder structure is
Foldernumber> and then 5 files, MP4, SMI, PPN, XML, BIM.
I'm sorry if I'm being dense but I've google around alot and found no workflow to help. Log and Transfer does not recognise the folder structure.
Many Thanks
Andrew
Shane Ross
Re: Problem Codec
on Feb 5, 2014 at 5:14:50 pm
That's because it's XDCAM. You need to use the XDCAM TRANSFER UTILITY for that.
Shane
Little Frog Post
