FCP Video Transparency
Boris Riabov
on Jan 31, 2014 at 5:08:10 am
How to take a form and change the color to transparent.
For example, a red triangle over a black background.
copy and reduce the size of the shape and paste it inside of the larger original and then turn this smaller triangle transparent so the result is a red outline of a triangle on a black background inside and out.
Dave LaRonde
Re: FCP Video Transparency
on Jan 31, 2014 at 10:14:28 pm
Use After Effects or Motion.
Dave LaRonde
Promotion Producer
Mark Suszko
on Feb 3, 2014 at 3:00:01 pm
Try using the luma or chromakey effect in FCP but also, if you're just putting a smaller version of one inside the other, try changing the blending (composite) mode, then scaling it down.
