Video clips enlarging slightly just before cuts in Quicktime Export
Scott Herriott
on Jan 31, 2014 at 4:00:35 am
Hey there...running FCP 7.0.3 on an IMac running OS 10.6.8.
Strangest thing, never seen before...after doing a Quicktime export on a documentary I'm working on I'm getting (several times already within the first 7 min.) quick image size changes just before a cut occurs. Nothing gigantic, but certainly noticeable and, obviously, not intended (as though a small quick zoom had been employed). It happens sometimes when there is a video transition and sometimes when there isn't. Any and all suggestions appreciated.
Thanks in advance,
Scott
Scott Herriott
Re: Video clips enlarging slightly just before cuts in Quicktime Export
on Jan 31, 2014 at 4:50:33 am
After checking the properties of the clips involved it looks like it probably has something to do with the Field Dominance. My Sequence Setting is "None". The clips that exhibit the strange zoom-in have "Upper (odd)" listed as Field Dominance. Is there a way to recify this?
Thanks in advance,
Scott
