Graphics Jitter / Vibrate over still pans
Marc D'Agostino
on Jan 30, 2014 at 9:37:56 pm
I have a lower 3rd graphics file and it looks great over all the video footage in my sequence, but when it is over a still image, the very top line of the graphic vibrates/jitters a noticeable amount. Any thoughts on why and how to fix? I'd rather not introduce blur if I can help it.
Is it a pixel aspect ratio issue with the stills?
I'm working in FCP 7.
John Fishback
Re: Graphics Jitter / Vibrate over still pans
on Jan 30, 2014 at 10:33:03 pm
If it's high contrast and interlaced that could cause the flicker. If there's a thin horizontal line at the top, that could be the culprit. You could try cropping a line or two and see if that helps. Otherwise, try a slight feathering of the edge.
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Mark Suszko
on Jan 31, 2014 at 3:14:47 pm
This is also made better and worse by subtle shifts in the overall vertical positioning of the text.
© 2018 All Rights Reserved
