Line out is one frame out of synch with picture
David Page
on Jan 30, 2014 at 2:39:51 pm
Using line out from the back of the tower to feed external speakers it appears my synch is a frame or so off ... time code proves it isn't, but it looks that way.I am feeding two apple computer monitors. I suspect there is a common fix for this. What is it? And If I want to ad a TV monitor as well, how do I do that?
Thnx.
Shane Ross
Re: Line out is one frame out of synch with picture
on Jan 30, 2014 at 5:30:34 pm
IN the SYSTEM SETTINGS under the FINAL CUT PRO menu, click on the PLAYBACK SETTINGS tab, and you can adjust the FRAME OFFSET there.
Shane
Little Frog Post
Shane Ross
on Jan 30, 2014 at 5:31:22 pm
As for connecting this to a TV monitor...you need a video IO device. AJA.com, Decklink.com, Matrox.com offer solutions. Cheapest are from decklink.
Shane
Little Frog Post
David Page
on Jan 30, 2014 at 5:54:02 pm
thank u
ps i enjoy your blog
